AS11 Freehand Broken line
Hi, AS 11 is great release, but sometimes i have a problem with freehand tool. I draw smooth line and when release button my line is broke. How fix this?
Re: AS11 Freehand Broken line
I think it's due to the GPU acceleration, disable it in display quality button to see.
But if it's that, normaly it's not appear when you rendering an image or video.
And welcome to AS11 club!
- Víctor Paredes
I can reproduce the problem.
Try setting the freehand smoothing option to another value, that fixes the problem in the meanwhile. I just created a report for it.
+1
In case it helps, just letting you all know, I experienced this as well.
Thanks for help! All work fine only if i disable smoothing feature. All other values give a same result. I like this smoothing feature and hope it will be work without artifacts in future.I think problem in wrong curvature. I try manually set 0.3 value to curvature but find another problem. Peak and Smooth buttons don't refresh curvature in viewport, refresh work only when change frame in timeline.
