Can you set file
happyowl
Can you set file
Post by happyowl »
Im trying to tune my workflow and one thing that bugging me is that after I export an animation to png files ('File, Export Animation...') I have to rename them all to meet coder needs of sequential file name suffix (e.g. 1, 2, .. 99. NOT Anime Studio default of 001, 002 ... 099).
I can speed this up a little using Adobe Bridge but it still leaves a few needing manual renaming.
Is there any way to change the export filename format from Anime Studio?
Cheers
HappyOwl
Re: Can you set file
AS doesn't offer the ability to use your own naming scheme. Usually I'm fine with it, but when I need it I use Renamer4Mac, a little utility which batch-changes the names of heaps of files. There's similar stuff available for windows. Look for "file name changer".
happyowl
Post by happyowl »
TY slowtiger
Was hoping avoid more software in the toolchain but if required that's a useful tip I will check that one out, i think i may have used it many moons ago.
