Rename a layercomp through script (LM_String problem)
JeroenKoffeman
Post by JeroenKoffeman »
Dear forum members,
I try to change a layercomp's name through lua. Is it possible?
comp:SetName(LM.String:Set(name))
Comp refers to the layercomp, name refers to a string.
It doesn't work. What's the proper way to change an LM_String?
Thanks in advance
Re: Rename a layercomp through script (LM_String problem)
If I remember correctly, you'd do something like this:
local string = LM.String:new_local() --define LM.String object
string:Set(name) --set LM.String value
comp:SetName(string) --use LM.String
JeroenKoffeman
Thanks, that worked.
