关于单独层动画
大家好  我是新人  可能大家会看不懂我的发言  那是因为我使用了谷歌翻译与大家对话,如果遇到一些不懂的大家可以看看我的中文,如果你懂中文的话
首先我想问的是一个层能够实现层动画吗?
在一个单独的矢量层内创建多个图形,它们之间有上下的关系,使用q工具能够让图形的层级改变,但是能够做动画吗
一个单独层的层动画
Animation on a separate layer
Hello everyone I was new and we may not understand my speech it is because I use the Google translation dialogue with you, if you encounter some do not understand the Chinese people can look at me, if you understand Chinese words
First, I want to ask is a layer of layer animation can achieve it?
Create a separate vector layers multiple graphics, up and down relationship between them, use q tools allow level change graphics, but you can do animation
A single layer of layer animation
						Animation on a separate layer关于单独层动画
- PRIMAL MORON
Re: Animation on a separate layer关于单独层动画
Ok, i'll give a crack at this, listen up!
You need to use animated layer ordering by putting all your layers in a folder if you want to move layers during animation. each object you want to move must be on it's own layer, you cannot move a chunk of one layer to another live during playback, it's all or nothing. To move the layers, first you need to go to the folder options and the layers tab, then enable the check box that says animate layer order, then choose the keyframe you want to switch the layers on, and move them up or down, from that frame, they will swap to that position, but it is a step, not a transition, so make sure you don't move it over another layer or it'll look like it's going through a solid object.
I will place my reverse translation below, if you don't understand, try translating this or talking to someone you know who can speak English fluently.
好吧,我给一条缝这个,听好了!
你需要把所有的图层文件夹中,如果你想在动画移动层使用动画层序。要移动必须在它自己的层每个对象,你不能在一个层的块移动到另一个现场在播放过程中,它的全有或全无。要移动图层,首先你需要去文件夹选项和图层选项卡,然后启用该复选框,上面写着动画层命令,然后选择你想要打开的图层关键帧,然后将它们移动向上或向下,从该框架,他们将交换到该位置,但它是一个一步,没有一个过渡,所以一定要确保你不将它移到另一个层或它会看起来它经历了坚实的对象。
好吧,我给一条缝这个,听好了!
PRIMAL MORON wrote:Ok, i'll give a crack at this, listen up!
好吧,我给一条缝这个,听好了!
谢谢你的讲解 我已经看懂了你所说的 但是并不是我想要的答案
那么我再次描述一下我的问题
首先我问的重点是一个层的动画,你会想为什么一个层可以做上下的动画,这不可能,没错只有一个单独的 矢量的图层 没有多余的图层 更加没有群组层的存在。
就一个层可以实现吗
Thank you for your explanation I've read that you said, but was not the answer I wanted
So again I describe my problem
First of all I ask is focused on a layer of the animation, you'll wonder why you can do up and down a layer of animation, this is not possible, it is true that only a single vector layers no more no extra layers exist layer groups.
It can be achieved on a layer
