Preview shows Antialiased Lines
Hi all
I'm having a strange problem. I'm trying to trace this Character, but since its pretty small on a Full HD Resolution, i have to work zoomed in quite a bit. Strangely, even though it's Vector, the Girl is displayed antialiased, as if it were a Bitmap Picture. It happens to every deselected Layer. When i'm on the Layer itself, it is displayed normally. This makes it extremely hard to work... I tried upscaling the Layers but to no avail...
When i open the Example Files everything is displayed correctly. I'm Using AS Pro 10.
https://drive.google.com/file/d/0Bwu0b_ ... sp=sharing You can Download the file here if you want to take a look.
Thanks for your help!!!!
Re: Preview shows Antialiased Lines
I found the Error. I leave the post open, in case anyone else encounters this: It was because i had GPU activated in my Display Settings... kinda weird maybe a Bug?
Yep, known bug. This post may help, if you want to use GPU acceleration: viewtopic.php?p=144157#p144157
