How to change the colour of an existing stroke? It's really hard to figure this one out. And is it also possible to change the colour of strokes between two points?
Thanks in advance.
- Francis Seven
Re: How to change the colour of an existing stroke?
Use the select shape tool to select the existing shape and then modify its style in the style window. You'll need to create a new shape to have a different style between specific points.
- Francis Seven
Thanks, synthsin. I'm also a bit confused as to why it is that when I drew my character's torso and added the stripes on his shirt with the paint bucket, it added a BUNCH of extra points and lines to the drawing. Now it's not manageable. Is there some way to fill in the parts with colour, without creating all this extraneous data??
Stripes. How do you think the software should know where to draw a stripe if not by drawing a vector line to attach it to?
Anyway, there are ways to keep thigs tidy and easy to animate. Once your art is bound to bones you don't touch the points (much). Stripes and other complex fills are often done in extra layers. Or you use an image texture.
- hayasidist
@Francis Seven: paint bucket is a bad choice.
how to get "stripes" (keeping it simple):
TURN OFF auto fill and auto stroke
draw a rectangle (just 4 points)
add one point on one side and draw a line across to connect
repeat
you now have 8 points and 3 smaller rectangles, let's call them A, B, C.
in the style window select the fill colour for one stripe
Using the "CREATE SHAPE" tool - select the 4 points of rectangle A and hit the "create shape" button;
repeat for rectangle C
in the style window select the fill colour for the other stripe
Using the "CREATE SHAPE" tool - select the 4 points of rectangle B and hit the "create shape" button.
hth
repeat
hth
- Francis Seven
Guys, thanks for the suggestions. Both have good ideas. I liked the idea of using imported textures and also the procedural method with rectangles.
But tell me, is it normal that styles keep disappearing from the drop down window?
