Soft Edge and mask problem
Mundokk
Post by Mundokk »
Hi ppl, I'm using AS since some years ago. I was using only bitmaps for my characters but I'm trying to use vectors right now.
I have a problem with masks and soft edges fills to make shadows, in the gradient edge it appears some white pixels at the mask edge (you can check the image of the problem). This not happens with plain fills.
There is the file: https://www.dropbox.com/s/gcbdhevdn4pvl ... .anme?dl=0
Somebody know how to fix this? thanks for your help :(
My layer panel if you need to check it
Mundo Co founder of
http://www.framefreakstudio.com
Re: Soft Edge and mask problem
I can't seem to duplicate your problem. Do you have a file you can share that shows the problem?
Mundokk
Post by Mundokk »
synthsin75 wrote:I can't seem to duplicate your problem. Do you have a file you can share that shows the problem?
Hi synthsin75, thanks for reply.
There is the file. https://www.dropbox.com/s/gcbdhevdn4pvl ... .anme?dl=0
Mundo Co founder of
I'm not seeing the problem using AS 10.1. What version are you using?
Mundokk
Post by Mundokk »
synthsin75 wrote:I'm not seeing the problem using AS 10.1. What version are you using?
I'm using AS 10.0 :shock: I'll update it. thanks a lot
Mundo Co founder of
Mundokk
Post by Mundokk »
Hey synthsin75, problem solved with AS 10.1 .
thanks for help :)
Mundo Co founder of
Glad to help. It's always a good idea to install any free updates (as these include bug fixes).
