Masking isn't working in the viewport
parseh
Post by parseh »
Here's the anme file:
https://copy.com/E6YR92YszKj9qPR3
Re: Masking isn't working in the viewport
You have to render to see masking results (assuming the masking is set up correctly).
parseh
Post by parseh »
But it does work in Selgin's models. Not sure what's wrong with my rig!
your character has nested masking - both head and the outer bone layer (layer12) are set up to be masking groups. As jahnocli says, you do need to render to see the results in these "complex" masking situations (yeah - it's a pain!). Selgin's pirate just has simple masking -- if you turn off GROUP masking in your head and layer12 groups the viewport shows you what you're expecting (and that's what the pirate has). I haven't looked into why you want masking at all 3 levels - but if you don't need it...
hope that helps!
parseh
Post by parseh »
I didn't know that! Thank you
