Refresh images in both images and sequencial images
ruscular3d
Post by ruscular3d »
In version 9 pro I used to be able to refresh the images after I redo a render without having to delete and reload images. Now even when I delete and reload the images it still remember the old images. I have 2 choices: Either I closed and exit and reopen the program to reload images or rename the new images to be loaded.
Anime studio only remembers the images that was last made and loaded. Is there another way to refresh the images ? Has the rules change, or is this feature no longwer working?
ruscular3d
Re: Refresh images in both images and sequencial images
refresh media works for rendering new animation, however it doesn't show up in the workspace, but only after rendering. rendering out a single frame preview doesn't update with refresh media.
If I don't get a response, then I am going to assume its a bug!
Hi, there was a bug report on something like this that was said to be fixed in 10.1? What version are you on, and what is the image editing s/ware that you're using?
ruscular3d
I am using the latest 10.1 and I am using poser 2014 to render TGA and PNG out the sequence animation.
Funny that this was reported as a bug, when I found a funky work around in the older version by resizing the images and then clicking undo function and it would refresh that way. Now the refresh media button doesn't work or the old funky way.
It will render out the animation correctly but not the preview render of stills.
