BUG? Maximum frames too low 2700 frames
Discuss Papagayo issues here
rdolishny
Post by rdolishny »
I think Papagayo maxes out at 2700 frames.
I have a wav file that's about 2000 frames long. When I bring in dialogue I can't access or see in any way the last few lines of text.
Only when I delete some text can I see the last lines.
Any suggestions (including maybe a bit of coding) to extend the max frame from about 2700 to something more?
rdolishny
Re: BUG? Maximum frames too low 2700 frames
Post by rdolishny »
... well you're not going to believe this but I figured it out.
By changing the frame rate to 40 I was able to see the text at the tail of my scene. I slid it left a random amount, leaving lots of padding at the end. Then, I changed it back to 30 fps.
:D
