Hi All
(Long time, hope you're well. I'm well thanks, lost a little weight.... Aaaanyway)
I am running 9.5, looking to upgrade to 10.1 (10.2?)
The big question for me is, does the meshinstance script work in 10.x?
It's an important question for me, as my rigs are lousey with meshinstance.
Thankyou for your time
I love you all equally, and without favour.
Adrian
meshinstance work in 10.1?
- Víctor Paredes
Re: meshinstance work in 10.1?
Just tested "syn_rl_merge_meshinstance_final_4.lua" and it seems to be working well.
MeshInstance: Instancing the positions of mesh points on vector layers
1. Use NAME for the name of the source layer, and NAME.<any or no name>.dup for all of the other layers
Like this: source: arm ---> instance: "arm.anyname.dup" or "arm.dup".
2. Set this script for all of the layers (ie. for the original and for the instances)
3. Modify always the source layer only.
-- written by Fazek -- modified by Synthsin75 (With help from Heyvern)
function LayerScript(moho)
local mesh= moho:Mesh()
if (mesh == nil) then return end
local ownLayer= moho.layer
local name= ownLayer:Name()
local tab
local mi= ownLayer.FA_MeshInst
local len= mesh:CountPoints()
local instName = ""
local a, b
local refname
local curve = nil
local curvePointID = -1
if(string.find(name, ".", 1, true) ~= nil) then
a, b = string.find(name, ".", 1, true)
instName = string.sub(name, b)
--print (instName)
end
if (string.find(name,instName, 1, true) ~= nil) then
--print (instName)
end
if (string.sub(name,-4) == ".dup") then
local refname
--copy instance
if (mi and ownLayer.FA_MeshInstName == name) then
--cached
if (mi[2] ~= moho.frame) then
print("MeshInstance: wrong order - swap the source and the copy!")
return
end
tab= mi[1]
if (mi[3] < len) then len= mi[3] end
for p= 1, len do
local pt= mesh:Point(p - 1)
pt.fPos.x= tab[p][1]
pt.fPos.y= tab[p][2]
--pt.SetCurvature(tab[p][3], moho.layerFrame)
for j = 0, pt:CountCurves() - 1 do --added by Ramon0 from here...
curve, curvePointID = pt:Curve(j, curvePointID)
if tonumber(curve:GetCurvature(curvePointID, moho.layerFrame)) ~= tonumber(tab[p][3]) then
--print("Slave---"..tonumber(curve:GetCurvature(curvePointID, moho.layerFrame)))
--print("Master---"..tonumber(tab[p][3]))
curve:SetCurvature(curvePointID, tab[p][3], moho.layerFrame)
end
end --...to here.
end
else
__,__,pref = string.find(name, "(.-)%.+") --name prefix
local __,__,sufx = string.find(name, "%..+(%..+)") --name suffix
local __,__,sufx2 = string.find(name, ".-(%..+)") --alternate suffix
if (sufx ~= nil) then
refname = pref..sufx --reference name
elseif (sufx == nil) then
refname = pref..sufx2
end
--print(refname)
local srcName= string.sub(refname,1,-5)
-- recursive search for the source
local stack= {}
local sp= 0
local document= moho.document
for i= 0, document:CountLayers() - 1 do
local layer= document:Layer(i)
local parent= nil
local sub= 0
while true do
if (layer:IsGroupType()) then
table.insert(stack, { parent, sub - 1 })
sp= sp + 1
parent= moho:LayerAsGroup(layer)
sub= parent:CountLayers()
elseif (layer:Name() == srcName) then
local mi= layer.FA_MeshInst
if (mi) then
if (mi[2] == moho.frame) then
tab= mi[1]
for p= 1, len do
--print(tab[p][1])
end
end --...to here.
end
ownLayer.FA_MeshInst= mi
ownLayer.FA_MeshInstName= refname
return
end
end
end
if (sub > 0) then
sub= sub - 1
layer= parent:Layer(sub)
else
sub= -1
while (sp > 0) do
parent, sub= stack[sp][1], stack[sp][2]
table.remove(stack)
sp= sp - 1
if (sub >= 0) then
break
end
end
if (sub < 0) then
break
end
end
end
end
end
else
--source
tab= {}
for p= 0, len - 1 do
local pt= mesh:Point(p)
local curve = nil
for j = 0, pt:CountCurves() - 1 do --Added by Ramon0 from here...
--table.insert(tab, { pt.fPos.x, pt.fPos.y, curve:GetCurvature(curvePointID, moho.layerFrame) })
--for k,v in ipairs(tab) do print(k,v) end
end --...to here.
end
--trick: FA_MeshInst won't change in the address space (no orphans)
if (mi and not ownLayer.FA_MeshInstName == name)
then
--cached
mi[1]= tab
mi[2]= moho.frame
mi[3]= len
else
ownLayer.FA_MeshInst= { tab, moho.frame, len }
ownLayer.FA_MeshInstName= name
name= name..".dup"
--avoid orphaning: update all dependencies
-- recursive search for the copy
local stack= {}
local sp= 0
local parent= nil
local sub= 0
while true do
sp= sp + 1
elseif (layer:LayerType() == MOHO.LT_VECTOR and layer:Name() == name) then
layer.FA_MeshInst= mi
layer.FA_MeshInstName= name
end
if (sub > 0) then
sub= sub - 1
else
sub= -1
while (sp > 0) do
table.remove(stack)
sp= sp - 1
if (sub >= 0) then
break
end
end
if (sub < 0) then
break
end
end
end
end
end
end
end
Thanks Selgin
I think the course of action for me will be to upgrade to 10, test my files, and hopefully transition to 10 from 9.5.
There appears to be a lot to gain in 10 over 9.5, for me the drawing tools will be helpful but also a big factor is the issue of appended style names appearing to have been addressed. I have built separate character rig files which I then import into scene files with respective backgrounds, and the style name bloat issue is a significant time sink (in 9.5.)
Thanks again
Adrian
Thanks again
Adrian
