Making imported sprites crisp
trantornator
Post by trantornator »
Hi everyone,
I made a little short animation using a bunch of old game sprites. Now when I rendered it, they all came out looking quite blurry.
Now I looked in the forums already and saw that there is a properties setting for importing new images that can be set to not smooth them out. Unfortunately I already have all of this set up and redoing it would NOT be fun.
I also saw that there are several options that can be set for the individual layers and I turned off smooth layers and ant-aliasing to no effect.
Any way to changet he settings for all the layers (over 50 in this animation) in one fell swoop?
Re: Making imported sprites crisp
anme files are plain text files, so you could create a duplicate and openin a text editor, find the setting you want to change, and do a search/replace on all.
To find the setting, create a new file, import just one image, duplicate the layr, set one to the desired settings, and have a look inside.
trantornator
Dude, that worked!
Note though, you can't use Notepad (it re-writes something in the header of the file and AnimeStudio won't recognize it any more).
The value in question is "sampling_mode" and if you don't want it to be dithered, you have to set it to 0.
Thanks again!
