Motion Graph Issues
APC
Motion Graph Issues
Post by APC »
I've been puzzled as to why I am unable to get keyframes into my Motion Graph. I am working in 9.5 and all I see in the Motion Graph timeline are brown lines representing movement. I cannot manipulate anything in the Motion Graph.
Re: Motion Graph Issues
You must doble click the channel icon you want, then you will be able to see the keyframes.
APC
Post by APC »
Yes!!! Thank you, Selgin. That did the trick. Now I have keyframes.
Nicohk92
Post by Nicohk92 »
I take advantage of this thread for a related question. I'm used in other programs to have a handle on each sides of my bezier points.
Here, the bezier option changes two points instead of one and with only one handle each. Is that normal? It is significantly more difficult to me. How should it be used?
Thanks
eric1223
Post by eric1223 »
interpolation works from one point and goes to the right until it reaches another point. What AS bezier does is have you only change the interpolation in between those 2 points, so there is 1 handle behind the first point, and 1 handle in front of the second.
Now if you want to have 2 handles on 1 point, you would have to change the previous point (or latter point depending on which point you want to have 2 handle) into a bezier point. I only recommend u do that if u need to.
