Reduce points
Reduce points
How can I reduce the number of points on my lines when using the point tool, I recently upgraded to 10 and found out that when I fill a line it comes up with lots of points that makes my artwork look weird.
" but what good is a muffin if your not alive to eat it" - agent 'smink'-----(lucky bob's time machine)
Re: Reduce points
to fill a shape, use "create shape" instead of the paint bucket as much as possible. (press U, then create shape).
Also with the paint bucket, if you click right on the line and not the inside the shape, it will "sometimes" not give you all those annoying points.
