Getting actual sharp edges on a line corner
jhbmw007
Post by jhbmw007 »
So even with the rounded caps option off, there is still some "rounding" that happens when trying to do a shape with very thick lines. Is there a way to fix this so that my squares corners below actually are pointy sharp corners on the outer edges instead of what's happening here:
Re: Getting actual sharp edges on a line corner
You're right, that's annoying.
Here's a workaround which uses one additional point per corner:
Add point, make it pointy (cmd-P), drag to side.
Moho 14.1 Mac Mini Plus OS 13.5
