Help with "New Document" - Tool Script
SimplSam
Post by SimplSam »
I have made a Tool script that creates a New Document - mimicking File New (or Ctrl-N).
I like clicking New on toolbars, so I am trying to replicate that functionality via the Tool panel.
The script function itself is as simple as can be, and it works:
moho:FileNew()
However... I have a couple queries:
1. Function Placement
I am not sure of the correct place to utilise this function call. Currently I have it in "DoLayout(...)". I tried putting it in 'new(...)', 'Run(...)' and 'Handle Message::self.Create', but they don't appear to be invoked for this.
2. Switching off / Resetting the tool state
I only want the tool to be momentary. I have no need for the Options toolbar, and once it has run there is no further functionality (until I need another new document).
The tool is left selected after the new document is created, and it will run every time I switch tabs (i.e. return to the 1st document) or try to close the application.
So I created a boolean state flag to say that the NewDoc tool is active, which prevents unwanted re-running.
Ideally the tool would be able to switch back to the previous/default tool (similar to how the Insert Text tool does it, but that seemed to do it by magic), so that I can use it again later, or simply eliminate the need for the state flag above. But I and can't figure a way to reset the state or detect when another tool has been selected.
So.... Just wondering whether you had any thoughts?
Thanks
Re: Help with "New Document" - Tool Script
I think it needs to be a button not a tool -- edit the _tool_list in your custom folder to have a line such as "
button IT_new_file ...
and the "main" function is
function <your service name>:Run(moho)
end
Please note the standard for naming is xx_yyy where xx is a personal identifier such as your initials or equivalent (e.g. LM_ is lost marble, I use HS_ ..) and yyy is descriptive text.
You might also like to look at lm_automation.lua in the program files -- (e.g.) C:\Program Files\Smith Micro\Anime Studio Pro 10\Resources\Support\scripts\menu\Script Writing\ -- which does this sort of thing
so, in more detail you'll have something such as
-- Provide Moho with the name of this script object
ScriptName = "IT_new_file"
IT_new_file = {}
function IT_new_file:Name()
	return "IT_new_file"
end
function IT_new_file:Version()
	return "1.0"
end
function IT_new_file:Description()
	return ("Create a new file")
end
function IT_new_file:Creator()
	return "iTeque"
end
function IT_new_file:UILabel()
	return ("New file")
end
function IT_new_file:Run(moho)
  moho:FileNew()
end
SimplSam
Post by SimplSam »
Viola!
And now I also see the magic of the Insert Text 'button'.
Excellent. Many thanks.
I think I have already through every AS script in the known universe trying to resolve this, but the missing piece of the pie was the 'button' invocation.
Thanks again.
iteque wrote:Viola!
Thanks again.
Yes, I always put in those extra instructions in my Menu Scripts installations for "button" tool use. This allows Debut users to use menu scripts as well. Any menu script can be used as a button tool by just dropping it in the tool script folder and making it a button.
