Anime Studio 9 Crashing after export with Imported Videos
Hopper200456
Post by Hopper200456 »
Wow, that title was a mouth full.
But yeah, I'm using Anime Studio 9.2 and I'm making an Outro.
(You know, at the end of most YouTube videos they'll have a screen with a bunch of other videos you can click on)
I imported a bunch of videos to do this (I'm pretty sure they were all MP4s) and everything works great.
But when I try to export it crashes everytime.
I think I can work around it for now, by adding the videos through another program, but in the future this may not be possible.
Anyway to fix?
Thanks for your time!
Edit: Wasn't able to use an external program. Have to use anime studio- and it won't stop crashing after export. Super annoying- as exporting this takes 2 1/2 hours. Please help!
More Edit: Still wont work. Switched to Mp4 format. Now it waits until it gets to the end, then crashes. This is great because it takes almost 2 hours to get to everything else.
Yes, even more edit: Regardless of any settings AS crashes every time. Gonna give up.... gosh darn it....
"Greatness from small beginnings."
Re: Anime Studio 9 Crashing after export with Imported Video
Does it have to be video? The images at the end of youtube are still images, so I'd do some screenshot from each video, trim it, and import to AS.
As for rendering: if it's only a certain frame rage wich gives you trouble, render in parts. Put those parts together in the video editor.
Hopper200456
slowtiger wrote:Does it have to be video? The images at the end of youtube are still images, so I'd do some screenshot from each video, trim it, and import to AS.
That sounds incredible\y painful :P
slowtiger wrote:As for rendering: if it's only a certain frame rage wich gives you trouble, render in parts. Put those parts together in the video editor.
I decided to downsize to 1080p and put it together in an external program. But now it won't stop crashing regardless of what I do. Whenever I try to export it crashes.
