Crane thing I made using AS10s Taget bones .
hammerjammer
Post by hammerjammer »
Hello All
Here's a crane sort of something I was messing around with just for fun a couple of weeks ago. I was having a hard time getting the 3 hydraulic cylinders I have on the rig to work correctly using bones, till TARGET BONES were added to AS10. I found a use for them on both ends of each of the 3 hydraulic cylinders. Pretty basic setup I guess, but It looks and works as cool as I hoped it would. I also used a tiny bit of Squash & stretch scaling on B3 Bone and Independent Angle on B5 Bone. (you folks can figure out where they are)
I just finish this a few minutes ago. Its going on 1am and my head hurts, I going to bed.
Here's the file. I have no secrets.
https://www.dropbox.com/s/skssoacy9qzjb ... 0thing.zip
HammerJammer
Hammerjammer
Pinesal
Re: Crane thing I made using AS10s Taget bones .
Post by Pinesal »
I wanted to check this out but it was made in a newer version of ASP than I have(9.0) so it wouldn't open.
versions before 10 don't support target bones, so it wouldn't work in older versions... time for an upgrade! :P
DK
Post by DK »
I can't open it even in 10. I think the zip is corrupt.
D.K
EDIT: Oops my bad.... I right clicked and saved target....did'nt realize it was a dropbox link.
The zip file works here. Might try again.
Nice example of target bone use.
Danimal
Post by Danimal »
One day I'll have Version 10 to check this out... :(
~Danimal
