AS 10 Add Point Tool Freezing
DK
Post by DK »
Hi.
Using As 10. Anyone experiencing the Add Point Tool freezing up? It's happening avery 10 minutes with me. Really frustrating when you are trying to work to a deadline. Looks like it's back to 9.5 for me again :evil:
D.K
Here's a screen capture of what's going down.
http://www.cartoonchef.com.au/forum/Bug.htm
Edit:
Bit more info....When it freezes I cannot use any other tools although I can select them. The last point I was working on remains red and all I can do is translate the layer around the screen.
Re: AS 10 Add Point Tool Freezing
On Windows I have had problems with AS using the ALT modifier more frequently (subtract from selection, etc.). It seems to get "stuck". I think hitting it several times will sometimes correct the problem.
May be a similar problem you are seeing.
DK
Post by DK »
Thanks Wes. I will try that and see if I can unstick things. I opened a thread on Mantis so will keep that updated.
Edit: Ahhh... Yes...it's when I use the Alt key this happens.
Cheers
D.K
