I'm kinda new at this, so anybody should be able to help...
Jdban
Post by Jdban »
I have drawn 2 circles so that they overlap eachother, and I want to create points at the two areas where their lines overlap. How do I do this easily?
Thanks in advance.
mwtoons
Post by mwtoons »
If I understand the question...just use the add point tool. (looks like a bent arc with a dot on it.)
Lost Marble
Post by Lost Marble »
Using the Add Point tool will have the side effect of changing the shape of the circles. Try selecting an entire circle and using the Scripts->Draw->Split Curve menu command. This lets you add extra points on an existing curve. Try different numbers of points, using Edit->Undo to go back, and find the right split for your needs.
