Image is following camera
dkwroot
Re: Image is following camera
Post by dkwroot »
The image isn't following the camera, the image is just immune to the camera movements. Find your image and double click on it in the layers palette to bring up layer properties. Under the "General" tab, look at the bottom options and you'll find a checkbox for Immune to camera movements; make sure that this box is not checked and click apply.
wizaerd
Post by wizaerd »
I'm still not exactly sure, but I think it might be parallaxing. Generally caused when things are at different Z positions. Unfortunately, I don't have access to the application or manual here at work, but this is pretty standard. Check the Z position of both your elements, and look through either the manual or menu for anything like lens effects or options.
sbtamu
Post by sbtamu »
wizaerd wrote:I'm still not exactly sure, but I think it might be parallaxing. Generally caused when things are at different Z positions. Unfortunately, I don't have access to the application or manual here at work, but this is pretty standard. Check the Z position of both your elements, and look through either the manual or menu for anything like lens effects or options.
That is exactly what it is.
Go back and reset all the z values on each layer.
Sorry for bad animation
