Need help with lua script to start Photoshop.
JeremyLavine
Post by JeremyLavine »
I've been lurking this forum for ages, and it's really been helpful. Anyway I found a script to launch Gimp, but I haven't been able to get it to work with good old Photoshop Elements 5.0, and would really appreciate some help with this.
Here's what I've have:
-- Provide Moho with the name of this script object
ScriptName = "SP_Photoshop"
SP_Photoshop = {}
function SP_Photoshop:Name()
	return "Photoshop"
end
function SP_Photoshop:Version()
	return "5.0"
end
function SP_Photoshop:Description()
	return "Launch Photoshop application"
end
function SP_Photoshop:Creator()
	return "Simple Scriptor, 2014"
end
function SP_Photoshop:UILabel()
	return("Photoshop")
end
-- The guts of this script
	function SP_Photoshop.getOS()
	if os.getenv("OS") ~= nil
	then
		local opSys = string.lower(string.sub(os.getenv("OS"), 1, 3))
		if opSys == "win" then
			return "win"
		else
			return "unix"
		end
	else
			return "unix"
	end
	end
function SP_Photoshop:Run(moho)
 if (moho.layer:LayerType() ~= MOHO.LT_IMAGE)
        then
	LM.GUI.Alert(LM.GUI.ALERT_INFO, "This Script only works with Image Layers.", nil, nil, "OK", nil, nil)
        return
        end
moho:LayerAsImage(moho.layer)
image = (moho.layer:SourceImage())
 if(SP_Photoshop.getOS()=="win") then
  os.execute(' "Photoshop" "C:\Program Files (x86)\Adobe\Photoshop Elements 5.0\PhotoshopElementsEditor.exe" ' .. '"' .. image .. '"')  --WINDOWS - EDIT path to Photoshop according to your system.
 else
 os.execute("Photoshop" .. image .."&")  --LINUX & Mac - edit path "Photoshop" if it doesn't work.
 end
LM.GUI.Alert(LM.GUI.ALERT_INFO, "Press 'OK' to reload image when you're done.", nil, nil, "OK", nil, nil)
moho.layer:SetSourceImage(image)
end
Re: Need help with lua script to start Photoshop.
I actually rewrote that Gimp script for PSE3 ages ago (should be an easy enough change to PSE5). All my old links to the script are dead, so give me some time to find it and repost it.
JeremyLavine
Hi synthsin75,
I've updated the script again since I noticed it referenced another by mistake, but it only works partially. When I start the script after selecting an image all I get is a pop-up stating "Press 'OK' to reload image when you'e done", but Photoshop still doesn't start.
I hope what you have works with PSE5. Does it also work with images within a switch?
Here you go:
http://www.filedropper.com/dreditinpse
You'll have to change the path to reflect PSE5.
This should work with any selected image layer.
JeremyLavine
Thanks, synthsin75!
Your script works like a charm with PSE5! Gonna save me hours! :D
Glad I could help.
Lukas
Post by Lukas »
Synthsyn75, do you know how to get this to work with Photoshop CC on OS X?
I've never worked with Macs, so I'm not sure what the exact path would be or how the image file would be provided as an argument for PS to open. It should certainly be possible though. Vern uses Macs, so may be he'd be willing to help.
gvboy
Post by gvboy »
Using the modified code below worked for me on Mac... just need to edit the actual app name of your version of photoshop (mine is "Adobe Photoshop CS5")
else
 os.execute('open -a "Adobe Photoshop CS5" ' .. image)  -- for MAC- Edit Photoshop App name
 end
Lukas
Post by Lukas »
gvboy wrote:Using the modified code below worked for me on Mac... just need to edit the actual app name of your version of photoshop (mine is "Adobe Photoshop CS5")
else
 end
Thanks so much! Finally it works :)
