Problem: Headturn does not work in 9.5.
Griseldis
Post by Griseldis »
Hi everyone,
I have taken a character from ASP 9.2 to 9.5 and then created a bone folder and want to work in the nested layer technology.
I've created a head turn action, where this also works, but not on the timeline.
I'm already think about since days on the problem and find no solution. Can anyone help me?
Below is the file in the dropbox for better understanding.
Best regards
Griseldis
https://www.dropbox.com/s/4mskglxk4aye7 ... arble.anme
Re: Problem: Headturn does not work in 9.5.
By default, 9.2 files (and previous versions) haven't the "Nested layer control" activated, so you must check it by hand. Just go to the bone layer proprieties > Bones tab > Allow Nested layer control.
Repeat the process with all the bone layers and sub-layers involved in your character.
Griseldis
Post by Griseldis »
He Victor,
thanks for your quick reply.
I have all bone layers checked and the sublayers too before I posted my file. But nothing works. That's what make me crazy.
What can I do?
Best wishes
Griseldis
You may have to go back to scratch and redo the smart bone actions.
I played around with it and can't figure out why it's not working. There seems to be some strange things going on.
For example, when activating the "Head-links" smart bone action and then selecting the effected layers it "deactivates" that action. It appears that the "head-links" action which is the head turning action, it's not properly linked to the head actions.
Doesn't look like things are set up correctly but can't say exactly what's going on.
Oh, then it could be you have the group or vector layers bound to a bone. When you bind an entire layer to a bone, it loses the smart bones influence.
I don't remember exactly how to solve it, but try with the menu Bone>Release Layer or Flexi-Bind Layer.
Griseldis
Post by Griseldis »
heyvern wrote:You may have to go back to scratch and redo the smart bone actions.
Thank you Heyvern,
I linked the whole CLAIRE KOPFGRUPPE at once to the headbone.
After that I create the headturn bone and made the action Head links.
Maybe that's the failure?
Best regards
Griseldis
hammerjammer
Post by hammerjammer »
Hello
Just for fun and to maybe help, I tried to delete the action and recreate it. That didn't work either. I Got the same results.
Something just not quite right. But, I don't know what's going on.
Sorry.
Nice character and rig though.
I like the hand turn and body turn on her right side.
HammerJammer
Hammerjammer
Griseldis
Post by Griseldis »
selgin wrote:Oh, then it could be you have the group or vector layers bound to a bone. When you bind an entire layer to a bone, it loses the smart bones influence.
Yes, it works! :D … so almost.
I rebinded the headgroup and than I have bound the sublayers individually. Now the headturn works, but without the mouth.
The reason: The switch layer for the mouth (Münder links rechts) can not bind to the head bone.
Griseldis wrote:
selgin wrote:Yes, it works! :D … so almost.
You must bind the points instead of the entire layer. If you are working with smart bones, NEVER bind a layer (that's the conclusion I got after some suffering :roll:).
Actually, with the ASpro 9.5 features, there's actually no need to bind a layer. You can bind points and use selective flexi-binding for images or vectors. That covers most of the needs.
I think layer binding must be "re-designed" to work with smart bones. It's a concept which used to work before 9.5, but not anymore.
Griseldis
Post by Griseldis »
hammerjammer wrote:Hello
Sorry.
HammerJammer
Thanx HammerJammer, for trying to help and your compliment.
Best regards
Griseldis
Griseldis
Post by Griseldis »
YES!
I got it! Thanx to all of you for generous helpfulness.
Griseldis
