I want to execute a python file from within Moho, as a tool.
I don't have much experience with lua, but I found the os.execute() command.
I don't seem to get it working from within Anime Studio Pro, but if I run the python file from the terminal, it works just fine.
Are there any steps I need to take account when I want to execute an python script from within Anime?
OS Execute from within tool
Re: OS Execute from within tool
See this script for an example: http://lostmarble.com/forum/viewtopic.php?t=12483
If the python file is not an executable, I think you'll need to pass that file as an argument to the executable to handle it.
Again, thanks for the reply.
Eventually it had nothing to do with the os.execute command.
I used debug.getinfo(1).short_src to get the path of the folder in which te lua script is located.
But because the path was longer than 60 characters, the path was abbreviated.
Now I use debug.getinfo(1).source and the problem has been solved,....for now
