why do the mouths move when i move that bone?
victorialatham
Post by victorialatham »
when ever i move the leg bone on my character the mouth switch layers move with it, can anyone explain why this might be happening? it only happens when i move this particular bone.
thanks.
Lost Marble
Post by Lost Marble »
It might be that the mouth switch layer has been attached to the leg bone. I can't say for sure without seeing the file. Try using the Bind Layer tool to attach the mouth switch layer to the head bone. Or, select the switch layer and choose the Bone->Flexi-Bind Layer menu command to let it automatically bind itself.
victorialatham
Lost Marble wrote:It might be that the mouth switch layer has been attached to the leg bone. I can't say for sure without seeing the file. Try using the Bind Layer tool to attach the mouth switch layer to the head bone. Or, select the switch layer and choose the Bone->Flexi-Bind Layer menu command to let it automatically bind itself.
thanks for the advice, could you please explain how to attach a switch layer to a bone or refer me to a tutorial?
thanks
victorialatham
its ok ive worked out how to do it thanks.
