from dark to light
sabina
from dark to light
Post by sabina »
Hi ~ I'm trying to create a sunrise scene. I made a vector layer that is just completely black, with the opacity turned to about 75 - this layer goes on top of the 'daytime' scene, so that the scene looks darkened. Then as the sun comes up, I gradually turn down the opacity on the 'black' layer until it's at '0'. Every time I turn down the opacity, I move the slider in my timeline up several numbers, change the opacity, then click 'ctrl F' to set the point. Only it doesn't work. :cry: After I render it, the scene just starts with the opacity on the 'black' layer at '0', so it begins in daylight. Hopefully someone can help? Thanks ~ Sabina
Re: from dark to light
Did you check "Allow animated layer effects" in the black layer before you created those keys?
sabina
Post by sabina »
Thankyou! I tried that, and it works! :D ~ Sabina
