Working Area v.5.2.1 no image when advancing frames
ingie01
Post by ingie01 »
In version 5.2.1 when a shape is made and filled every thing is fine in frame 0. When frame is advanced, no image. When tutorials are loaded and run images appear but have line thickness changing wildly and erratically. I have version 5.0. and do not have this problem. Version 5.0 works as it should.
Win XP sp2 Intel Pent4 2.6 Ghz 256 mgb ram wacom tablet intuos GD
You'll know when you get there! My Dad
Lost Marble
Post by Lost Marble »
That sounds very strange. Has anyone else seen this, the wildly-changing lines in tutorial files?
ingie01
Post by ingie01 »
If I knew how, I would post a screen shot of the problem if that would be of any help. Very strange indeed since when I first installed v.5.2.1 it worked perfectly well----
Lost Marble
Does it happen with a new, empty project where you just create one shape? Or is it in a particular file you're working on? Maybe there's something strange going on in that file.
melkman
Post by melkman »
you can easy make a screenshot:
press Print/Druck ( right near the F12 Key)
then open your gfx program.
Make new File (perhaps size is createt right automatic).
With the new empty document in your GFX prog ,
Go menue Edit / Paste .
Tataaaa .
Then you can save it normal.
Greetings me (lkman)
melkman
Post by melkman »
Tataaaa .
ingie01
Post by ingie01 »
Dear Admin,
This happens when I create a new project, shape. When I open or import a project or object, then the line quality becomes erratic but I can see the object(s) in the work area.
ingie01
Post by ingie01 »
I have .jpeg screen shots of the problem, but I do not know how to post them on this forum. I see buttons at the top of post a reply but I do not know html or how to get my jpegs to show up here.
ingie01
Post by ingie01 »
Problem Solved!-----
I sent off a note to support@lostmarble.com and they immediately sent back a fix. deleting the application data user files and user settings did the trick. Don't run Moho while you are doing this.
