Searchin a script that pastes keyframes to different layer
Lukas
Post by Lukas »
Hey guys,
Does anyone know of a script that can copy/paste keyframes from layer to layer?
I've got some layer-(translate,rotate,scale) keyframes on a vector layer, but then discovered it needed some bones, so I'd want to create a new bone layer, cut and paste the keyframes from the vector layer to the bone layer. And put the vector layer inside the bone layer.
This seems so simple I wonder why it's not natively in ASP. But I'm sure I'm not the first with this problem, has any scripter solved this yet?
Re: Searchin a script that pastes keyframes to different lay
If I remember well, there was an old Crashcore's script which made that. But it is from the Moho days, so probably it will need to be updated.
viewtopic.php?t=2448
viewtopic.php?t=3026
Lukas
Post by Lukas »
Ah yes, I remember them.
I'll give it a shot, thanks Selgin!
Lukas
Post by Lukas »
Oh...it seems the links to the scripts are offline... :(
Do you still have the scripts perhaps?
Lukas
Post by Lukas »
Thanks!!!
Bossco
Post by Bossco »
Do they still work for AS 9.5?
Lukas
Post by Lukas »
Not really :(
