Autoplay Off?
Autoplay Off?
Is there a way to disable 'autoplay' of a movie file after rendering. It seems like this feature should be an option but I can't find any way to switch it off. I really don't want the program to do this because I need to immediately load the file into my NLE but the 'autoplay' keeps disrupting my workflow.
Thanks for any info or tips regarding this matter.
G.
Re: Autoplay Off?
You can't disable autoplay in the normal render, but you can use the batch render instead.
Re: Autoplay Off?
Thanks Selgin. I haven't tried the batch render command yet but it sounds like it should do the trick.
G.
Re: Autoplay Off?
Oh, yeah, I guess that is better since it means I can continue working while the scene renders in the BG. Thanks again for the tip! That fits into my workflow nicely. :)
G.
