Audio Recording in ASP7 :( !
Morfeo99
Post by Morfeo99 »
Hi! I've met a problem with anime studio pro 7 with the "audio recording". When I try to record my voice on the software, the "audio recording" panel doesn't incorporate the sound. I'm not seeing even the red bar that usually I see when i record my voice :cry: . I tried in every way to record my voice: with the microphone, without microphone ... I can't do it :( . Does anyone know how to solve my problem?
Sorry for my bad english but i'm italian :oops: .
See you soon,
Morfeo99.
SvenReyter
Re: Audio Recording in ASP7 :( !
Post by SvenReyter »
I've only used that feature once or twice. Are you using an interface, USB mic or your PCs internal mic? Have you checked your recording devices/properties to see if a mic/Rec interface is in use or if the recording volume level is set properly? It could be something really simple.
I use other software to record voice and import the mixed wav file into Anime Studio. Audacity is a free recording software that works pretty well and it will give you a lot more options than Anime Studio's sound recorder.
Download Audacity and try this first, to make sure your computer is OK.
