can i use Papagayo with other languages
Discuss Papagayo issues here
saydfuad
Post by saydfuad »
Please anyone tell me if i can use Papagayo with other languages not ENGLISH, ITALIAN OR SPANISH . and how :shock:
-Animation is all about timing and spacing.
http://www.saydfuad.wordpress.com
Re: can i use Papagayo with other languages
take a look at http://www.lostmarble.com/papagayo/
more inspiration on adding other languages is here: http://www.lumenvox.com/knowledgebase/i ... AA-00624/0
saydfuad
Post by saydfuad »
Thanks for replay..how i can add my language support in papagayo, please?
download the source code from the papagayo site (bottom of that page), and take a look at the readme in that download package. That will explain the process of adding a language.
and/or you might choose to add a pronunciation dictionary for your words as per the example from the lumenvox link for example (assuming Swahili, but of course that might not be the language you want): HABARI HH AE B AE R IH
this would work well except for phonemes that are not used in "European" based languages where you'd need to make the best choice from the CMU set of 39. In practice this shouldn't be a big issue as these are mapped to the (9+rest) PB mouth set... unless those shapes are not appropriate for the language used.
Good luck!!
villatlf
Post by villatlf »
I am trying to use Papagayo in Spanish. The button to select languages does not work. There is no "readme file" in the Papagayo software download with instructions, no users' manuals and no reference to it in the tutorials.
Where can I find instructions on how to install other languages (Spanish)? Can I create my own phonemes? How?
Francisco
which version of papagayo are you trying to use?
villatlf
Post by villatlf »
I am using version 2.0b1
Francisco
I *think* you'll need to use 1.2; version 2.0b1 is a beta release.
villatlf
Post by villatlf »
Yes, versión 1.2 works fine in Spanish. New versión 2.0 does not work in Spanish. Problem solved. Thank you.
Francisco
