9.5 Smart Bone Feature Help
toast
Post by toast »
I need help:
I have no problem using smart bones to fix joints and make pupils move/dilate. I understand the process and it is very simple. I upgraded to the new 9.5 for the layer order control and layer visibility and I cannot figure out how to make it work. I use the same process and adjust the layers on the layer window, but when I move the bone, nothing happens.
Any insight?
Thank you
Re: 9.5 Smart Bone Feature Help
double click your bone layer and make sure that 'enable animated layer order' is ticked under 'depth sort' tab.
toast
Post by toast »
funksmaname wrote:double click your bone layer and make sure that 'enable animated layer order' is ticked under 'depth sort' tab.
Thank you!!!! I wish this was in the documentation. It was obvious to look there. Thank you! :D
page 179 ;)
