Hi guys,
if any of you use Deadline 5.2 render farm, it's now compatible with ASP 9.5. For the time being, you'll need this patch. Just replace this file in your Deadline repository plugins folder and (if necessary) check the path to the 9.5 exe. Do this by opening the deadline monitor, tools > superuser mode > configure plugins > anime studio, and find your ASP exe file (either/both 32bit and 64bit). This should be taken care of, but it may point to an old path so it's best to check.
If you're happy using ASP 8 with Deadline, you're best to leave this alone as it could break ASP 8 functionality.
Thanks to Ryan from Thinkbox for identifying the problem and patching it for us this week.
http://forums.thinkboxsoftware.com/down ... hp?id=4295
Mark
Deadline 5.2 now works with Anime Studio 9.5 with this Patch
barrierstrobe
