How to set a region on the time-line?
- djwaterman
I'm wondering if there is a way to set a region on the time-line for the purpose of previewing just that section, I'm doing some lip sinc and I'd like to just play small sections while make adjustments. I'm thinking of how it is done in After Effects, is there a technique for doing something similar in ASP?
Re: How to set a region on the time-line?
alt-right and alt-left-click in the line with the frame numbers.
- djwaterman
Boy, talk about speedy response. You are legend. Thanks so much.
- Víctor Paredes
Alt+click defines the length of the final render. If you only want to preview a segment, use Ctrl+click instead.
