After working in AS Pro 9 for a while, it stops recognizing my key strokes. I will press G to switch to the lasso tool but when I click I find the earlier tool is still active. (Clicking the select tool icon works.) I will press Ctrl+C then Ctrl+V but nothing will be pasted. (Clicking Edit | Copy and then Edit | Paste works.) All keyboard shortcuts are affected.
At first I thought there was a problem with my keyboard not recognizing key presses, but if I click to another window (such as my web browser) my keyboard works fine there. When I switch back to AS Pro 9 my key presses again are not recognized. That's why I think this isn't my keyboard's problem.
If I close AS Pro 9 and restart the application, my keyboard works again. At least for a while until the problem returns. I'm using the Mac version. Has anyone else experienced this behavior before? It's very sporadic but quite annoying when it does happen.
Keyboard Shortcuts Sometimes Don't Work Until Restarting AS9
Re: Keyboard Shortcuts Sometimes Don't Work Until Restarting
I have noticed that the shift or alt key acts like it's stuck sometimes. Pressing each will "remind" AS neither is held down.
That could be what's doing it; thanks. I'll pay closer attention to see if I can use Alt or another key to fix the issue without restarting the program.
Also I forgot to mention I'm using AS Pro in 32-bit mode. I almost never used it in 64-bit mode, though, so I don't know whether that might make any difference. I get MP3 files from most of the voice talent I work with so 64-bit mode isn't an option until I train them to switch formats. :)
