Animating styles
JCook
Animating styles
Post by JCook »
Is there a way to animate a style change? That is, the styles in the style menu. Say I've made a style that has one fill color and outline, and applied it to an object, but later on I want it to change to another style with different fill and outline characteristics. Can that be done? I havent' been able to figure it out, or find it in the documentation.
thanks,
Jack
Rai López
Post by Rai López »
You can animate the Fill & Outline color when you have selected de desired Style in Style Window (you'll see the specific keyfrafmes of each style), then you apply the style to any shape and the color/transparency will change to every "styled" shape (that is GREAT!) ...But if you want change to one style to other (includig effects and more) along the time, I think it's not possible, although you always can create two shapes (one over the other) and play with transparecy to make the change between them when you want... HOPE help! :)
JCook
Post by JCook »
Thanks Ramon, this might be a good thing to request for future Moho.
Jack
