Can LM add a function to adjust the playback speed to v.5? Or, is this possible with Lua?
Thanks
Playback Speed
- Lost Marble
Go to the File->Project Settings menu command, and you can set the frames per second.
When you play back the animation within Moho, Moho tries to play it back at the correct speed. However, depending on the complexity of the animation and the speed of your computer, the animation may play back slower than it should. There are two things you can do:
1. Make some layers invisible. For example, you don't always need to see the background elements when working on a foreground character. Turning off the background or other characters can speed playback.
2. Select Animation->Allow Frame Skipping. When checked, Moho will skip frames during playback (when necessary) in order to keep the overall playback speed as close as possible to the project's desired frames per second.
