ASP 9.5 Lip Syncing Issue
highrise955
Post by highrise955 »
Has anyone noticed that lip syncing characters, via 'Mouth Switch Layer' to imported audio doesn't seem to work nearly as well as it did before the upgrade. And I don't mean just slightly worse, I'm talking about entire words and sometimes more being completely skipped over. I even opened an old animation, deleted the keyframes on the mouth layer and then re-added them via the "Select audio sync source" in the Switch tab. It wasn't even close to the way prior 9.5 versions did it.
Anyone else seeing this?
Re: ASP 9.5 Lip Syncing Issue
I just did a few tests on my own using the audio recording and linking switch layer phonemes. It appears to be working, for me anyway. I haven't done any comparisons with older versions, but I don't see any really bad syncing. I noticed when typing in the dialog text in the audio layer, the switch layer lost it's connection to the audio file and had to be relinked. I don't know if it did this before or not.
bill_lake
Post by bill_lake »
I've noticed a similar issue but have not troubleshot it yet.
