Hi All,
Recently I had to uninstall and reinstall Anime Studio Pro 8.2, and when I did most of my encoding options disappeared. Now I can only export animation as an AVI; I'm using Windows 8, is there something I need to do to get the other choices back?
Thank you in advance.
Encoding options disappeared (Anime 8 Pro 8.2)
Re: Encoding options disappeared (Anime 8 Pro 8.2)
Quicktime is not supported in 64 bit - check your version.
- hayasidist
did ASP8.2 have a 64 bit version? I thought ASP8 only ran in 32 bit mode on 64 bit tin. (full 64 bit support arrived in ASP9?)
maybe whatever caused you to re-install AS also knocked out QT? (I'm guessing that the image sequence options are still there - JPEG...PNG - so if you've not got PSD or Flash - also check your Adobe programs?)
Yeah, the image sequence options are still there but they're not ideal for my purposes. QT was there, as was MP4, which is what I used to use. Files were 10-20mb, now with AVI they're nearly 300mb, and I've used up all my scratch disk space.
Anyway, Anime 8.2 is 32-bit only.
I may have spoken too soon, there appears to be a 64-bit version of 8, according to the "installing the update" page. But for 8.1 only?quikib wrote:Yeah, the image sequence options are still there but they're not ideal for my purposes. QT was there, as was MP4, which is what I used to use. Files were 10-20mb, now with AVI they're nearly 300mb, and I've used up all my scratch disk space.
