The head turn only uses 2 inbetweens and good follow-through.
(Part 76 of my ongoing campaign against full 360° head turn rigs ...)
Ha! I agree about head turns. I probably wasted more time on them than anything else. Mine could definitely use improvement, but I don't think I've ever used more than a few frames to do one. A split second of action hardly seems worth the days I spent trying to getting one to look perfect. Live & learn
If I had a boss looking over my shoulder, like some of you guys on the pro level have, I would have been fired a loooong time ago.
Nice example. Thanks, Slowtiger.
Anyway, I'm not against 360° headturns (although 360 are too many degrees for my taste). I like to have very flexible rigs in which I can rotate the head and count with a wide range of angles. The real problem is about animation, if you make a headturn using 30 frames instead of 3 that's not a problem of your rig, the problem is your animation is probably bad. The same thing happens with 3d characters.
I always like to animate animals like rabbits or birds because of their fast movements. I think 360° (or less) headturns and fast movements can be friends.
