Layers transparent after rendering
geoffganz
Post by geoffganz »
Hello to all. First post on this forum. I recently began using Anime Studio Pro 9, and I need a little help with an issue. In program, all of my layers are non-transparent after making sure the transparency option is turned off on all layers. But when I render it to AVI and play it, the layers are transparent. Is there a general setting I'm missing somewhere? Please help. Many thanks.
Geoff Ganz
Re: Layers transparent after rendering
Are you sure the opacity is set to 100% in these layers?
Do you use a different layer blending mode than "colour"?
Droxon
Post by Droxon »
Try rendering in other formats just to test it,
I always have issues rendering video formats in anime studio
thats why I always render png sequences and then I do the final render in After effects.
geoffganz
Post by geoffganz »
I appreciate both of the responses. I looked into all suggestions. Opacity at 100% for all layers, yes. I did try other rendering formats, but the results were the same. Layer blending mode is set for normal for all layers. When I set it for "Color" for all layers, the results were the same.
Any other suggestions? Much appreciated!
I would say at this point it would help to see the file if you could upload it somewhere.
