reload scripts without exiting AS
In Vern's recent "scripting" webinar there was, IIRC, mention of "use this key combination to tell AS to reload the scripts" as a useful timesaver when developing a script that goes through many iterations before it's working.. something like ...
never mind, got it :oops: : ctrl-alt-F5. I'll leave this here as a reminder for me and other scripters
Maestral
Re: reload scripts without exiting AS
Post by Maestral »
Thanks. I knew it`s F5 but would never guess that Ctrl+Alt combo.
I`ve tried to find where I picked it up at first, in order to refresh my memory, but no luck till this moment 8)
Thanks a ton!
ernpchan
Post by ernpchan »
Is it as simple as just doing Ctrl+Alt+F5?
It's not working for me... :?
My opinions and comments do not represent those of my employer.
http://www.ernestpchan.com
http://www.zazzle.com/gopuggo
Stan
Post by Stan »
It's Ctrl+Alt+Shift+L now. And it's configurable via the Help menu.
ernpchan
Post by ernpchan »
Stan wrote:It's Ctrl+Alt+Shift+L now. And it's configurable via the Help menu.
Thank you!
I changed mine to Shift+S. For some reason, that's the only way I can remember it.
yeah - the OP was for AS9(.5)?? A whole lot has changed since then.. including needing to be able to make that 4-key combo ... I'm thinking that it might have been set up as a practice exercise for aspiring concert pianists :roll:
ulrik
Post by ulrik »
hayasidist wrote:yeah - the OP was for AS9(.5)?? A whole lot has changed since then.. including needing to be able to make that 4-key combo ... I'm thinking that it might have been set up as a practice exercise for aspiring concert pianists :roll:
:lol:
Defims
Post by Defims »
It seems Command+Alt+Shift+L and Ctrl-a-Alt-Shift-L not work on moho 12 mac version. which shortcut will be ok for moho 12 mac version?
chucky
Post by chucky »
Yep I can never remember it so I have a special shortcut (on my phone -true) for that.
SimplSam
Post by SimplSam »
I always though that that was a hideous key combination anyway.
So just go into [Edit] > [Edit Keyboard Shortcuts] ... search for Reload, and change the shortcut to something more sensible.
