Test from a project
spoooze!
Test from a project
Post by spoooze! »
Here's a test I did last night for a project I'm writing called "Beyond the Bowl". It's going to be animated along side "Death From Above
http://webzoom.freewebs.com/jtn1989/Fish.mov
More story details will come later. I'm also still working on the fish module. I'm gonna add "arm" fins also and teeth. I'm also working on making the bubbles transparent.
If anyone wishes to animate on this project (it will be volenteer work) please PM me.
Spoooze :!:
mwtoons
Post by mwtoons »
I am working on an underwater animation as well. I have bubbles in mine and I use a particle layer with three different bubble sizes. You can also very easily make them transparent.
mwtoons
Post by mwtoons »
I just tried exporting one of my scenes as swf instead of quicktime and noticed that you lose a lot of effects when you use swf. If you are having trouble, I suggest trying quicktime as and output to see how things look. I lost my transparency when I tried exporting as swf.
hth
mw
spoooze!
Post by spoooze! »
How would you make them transparent?
Spoooze!
mwtoons
Post by mwtoons »
double click on the switch layer to see the prefrences. There is a opacity value you can change.
mr. blaaa
Post by mr. blaaa »
spoooze! wrote:How would you make them transparent?
Spoooze!
:shock: :!:
