hello everybody
i would like to make as i done before one time but i forgot how
i just want to fill a form with a vidéo made for
as texture vidéo under anime studio 5 i remember having done it
but i canno't do the same under anime studio pro 8
any help would be great
regards to all
how to have a fill video texture ?
- labonneanime
Re: how to have a fill video texture ?
Works for me.
Create shape, choose effect 1, image texture, choose video file, OK, space.
It doesn't show in preview, you have to render it to see the effect.
Only drawback is that I can't set the video to loop, it stays on the end image after one play; and I can't scale it properly.
I'd rather use a video layer with a mask, this way I have more control over the video.
- labonneanime
hello slow tiger
thanx a lot
i go make a try right now
regards
thanx a lot
regards
- labonneanime
ooops me again
it was a problem of vidéo codec
so now it is working
but
the fact is that in 5.5 version i have done a deformation of vidéo by changing
the splines form, i canno't tell you right now if this is efficient yet but i
am asking you if it would be possible yet ? my computer is actually calculating
the main vidéo to be put on the splines
thanx yet
steff
but
thanx yet
steff
Moving the points of a shape actually doesn't change the video.
What you need is bones. Be sure to check the "warp with bones" option in the video tab. Have a chain of at least 3 bones in your shape.
- labonneanime
hello dear sir
pleaz accept my appologies, i did success as you told me to do and i forgot to write you
back. thank you so much. regards
