I'm creating 101 5-10 second animations for a company who plans to publish a book with QR codes linked to my animations.
The animations are of similar quality to these animation that I've created:
https://www.youtube.com/watch?v=jMSUbPyJxZ4
https://www.youtube.com/watch?v=ahBg1iZ-aNE
https://www.youtube.com/watch?v=tyxy1z0hP7c
https://www.youtube.com/watch?v=W0LmFORd4QI
I'm just having trouble trying to figure out how much i should charge.
Is $500 dollars for each set of 50 animations too little?
How much should I charge for animation?
Re: How much should I charge for animation?
You should generally charge a living wage for the time it takes to produce the animation.
Each animation takes 15-20 minutes to make...synthsin75 wrote:You should generally charge a living wage for the time it takes to produce the animation.
Any idea on what a reasonable price would be?
Take the time to produce, including content creation (not just animating), and multiply that by the hourly wage you require to make a living. Reasonable is only somewhere between what it takes to not starve doing a job and what the market/customer will bear.
synthsin75 wrote:Take the time to produce, including content creation (not just animating), and multiply that by the hourly wage you require to make a living. Reasonable is only somewhere between what it takes to not starve doing a job and what the market/customer will bear.
Thank you.
Your advice was very helpful.
