How do I change the transparency/alpha of an image?
Hopper200456
Post by Hopper200456 »
Hey guys.
YES, I know I've asked tons of probably stupid questions here, but, hey, switching from AS 5 to AS 9 Pro is difficult I guess.
Anyway, so in this animation I'm working on (the Metroid one which I've asked about before.) I want to having something fade in.
But, the things I want to fade in are images imported in, not vectors. So, in short:
Is there anyway to change the alpha/transparency of an image layer?
Thanks for helping!
If for whatever reason, you need images just ask and I can provide. :)
"Greatness from small beginnings."
Re: How do I change the transparency/alpha of an image?
You animate the opacity of an image layer the same way as in a vector layer.
Hopper200456
.... And how do you do that?
The way I've changed the transparency of a vector layer was my changing the alpha of the fill and outline color... But thinking about it now I realize how much of a pain that was and how I was doing it the hard way...
You need to turn on the "Allow Animated Layer Effects" in the layer properties window. Then animate the Opacity % of the image layer in the same window. This also works for any layer type.
3deeguy
Post by 3deeguy »
In Pro 7 you have to render the image to see the change in opacity. A vector layer does not have to be rendered first. (I've got to get pro 9 so I'll be up to date)
Cheers, Larry
Hopper200456
heyvern wrote:You need to turn on the "Allow Animated Layer Effects" in the layer properties window. Then animate the Opacity % of the image layer in the same window. This also works for any layer type.
Oh, duh, thanks! This'll work fine :D
3deeguy wrote:In Pro 7 you have to render the image to see the change in opacity. A vector layer does not have to be rendered first. (I've got to get pro 9 so I'll be up to date)
I'm using Anime Studio 9 Pro, but this is good for anyone who is using 7, and looking for help! :D
