Blend Morphs in debut?
under the Window menu there is an entry called blend morphs. When I select it, I get a message saying there is no bendable morphs in the layer. When i look up more info, it seems the function is tied to a window called "actions" but debut doesn't have that. Is blend morphs usable in debut?
- Víctor Paredes
Re: Blend Morphs in debut?
Debut version can't create Blend morph targets, because they need to be made with actions (a Pro feature). However, Debut can open a character created in Pro and animate it with Blend morphs (if there's any target).Pinesal wrote:under the Window menu there is an entry called blend morphs. When I select it, I get a message saying there is no bendable morphs in the layer. When i look up more info, it seems the function is tied to a window called "actions" but debut doesn't have that. Is blend morphs usable in debut?
I see. That explains why that is there then.
