Particle layer editing ?
cableon
Post by cableon »
Hi everyone,
pardon my naïve question, but is there a way to tweak a particle layer settings on specific keyframes in ASP9, instead of just setting its parameters once and for all ?
I checked the user's manual and did not find anything regarding that matter.
Thanks for your help!
Re: Particle layer editing ?
No, particle layers proprieties can't be animated. Anyway, remember you can animate the contained vector layers, which is a very powerful feature.
Actually, many times I set all the velocity related parameters to zero (or close) and control the particles by animating them by hand. You can create very fancy stuff.
cableon
Post by cableon »
Oh, ok thanks...
The trouble in my case is that the particles themselves are image layers, not vector ones...
Thanks a lot however, manipulating vector particles seems to be a handy trick indeed!
Thank you!
cableon wrote:Oh, ok thanks...
Thank you!
You are welcome :)
Anyway, you also can animate image layers (translation, rotation, scale, opacity, etc)
