Use Bone Strength but seperate the legs?
skygaz3r
Post by skygaz3r »
hello guys,
normally if i build a character i set the Bone Strength to zero and then bind the vector to a bone.
I made i character and and did this as well but i wanted to use now the Bone Strengh to let the leg look more flexibel.
The thing is, if i use Bone Strength and even reduce it to a minimum, it still keeps moving other vector.
Example: I use the Bone Strength on the one leg but it as soon as i move the Bone it also stars moving the other leg :/
Is there somehow a way to avoid this?
sorry, my english isn't good ;(
Re: Use Bone Strength but seperate the legs?
Read the manual about "bone offset".
skygaz3r
Post by skygaz3r »
guess i dont get it :/
if i use offset bone i just can push around the bone and the leg but i cant somehow "bind" it with the bone strength
rocky53204
Post by rocky53204 »
Tutorial 3.4 “Character Setup” in
your Anime Studio Tutorial Manual.
skygaz3r
Post by skygaz3r »
yes i know i am in the manual at 3.4 but maybe my english is just so terrible that i dont get the point what to do oO
i mean i know that i have to give the bone just a limited strength, but it seems that it catches still stuff that is actually out of its range :/
it looks like this http://postimage.org/image/lcvaskdqp/
Well, just call it a skirt? *fg*
Seriously: first, you need to make sure to use flexible binding, because any bone strength will only work with that.
Then, don't set all bones to strength=0. The Offset bone trick works in a way that it calculates the distance between the bones and their relative strength to each other in order to decide which bone controls certain points. If you set everything to zero, adding more distance will not help. Try to set each bone's strength so it just covers all the points it shall control.
Of course it's possible that you still have single points bound to the wrong bone. In that case select those points and choose "release points" from the menu.
skygaz3r
Post by skygaz3r »
hm i guess thats where it goes all wrong for me :(
everything of the body has the bone strength set to 0 except the bones on the leg. so its not possible to combine this two kinds of using bones?
skygaz3r
Post by skygaz3r »
ah okay now i got it :D
didnt know how to use bind points before - thx 4 helping me out :)
yaoiloverel
Post by yaoiloverel »
I saw your post. I also see that you got help with your problem. In your first post you said you wanted to use bone strength to move your legs. If that is still something you may want to do, here is a video that will help you out.
http://www.youtube.com/watch?v=qJzR4661i_U
I think this is what you where trying to do at first. I hope i helps.
