Quicktime substitute for AS9 Pro 64 bit?
kirkshoe
Post by kirkshoe »
Is there a Quicktime substitute codec for AS9 Pro 64 bit? Where to download?
Re: Quicktime substitute for AS9 Pro 64 bit?
Quicktime is not a codec but a framework. No, at the moment there's no substitute.
chucky
Post by chucky »
If you really need a replacement I have found that the lossless avi codec (which importantly supports alpha) is one called lagarith.
If you really can't use QT then give that a go.
The switch to 32bit function in AS is pretty good which will get you through a QT render otherwise until another solution is found. :D
